Diesel Forum - TheDieselStop.com - View Single Post - Ordering Information
Old 11-28-2007, 10:45 AM   #5 (permalink)
PowerStrokeHD
Re: Ordering Information
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: loft306</div><div class="ubbcode-body">Goto the dealer and get him to give you a copy of the DORA it will have the vin on it...or atleast the true order number and the dealer nubmber and your sales persons name and a few other things and then read the vin tracking 2008 thread and on BON and call VOPC pretending to be your dealer and ask if the vin is available...they will then give you the first 2 digits and the last 8 digits if the truck has been serialized and the dora will have all the rest but the check digit if you have that much you can probably force the vin outta the dealer....though i have seen the guys at BON work with 16 digits if you tell them that the check digit is missing. As in the first 2 are 1F then what is on the DORA then last 8 xxxxxxxx like 1Fxxxxxxx_xxxxxxxxx though try the dealer first and if you call VOPC and they give you the first2 and last 8 then go back to the dealer but obviously dont tell them where you got the info...
P.S. the DORA also is a good way to make shure that what you ordered is what was recieved by ford. </div></div>
All you really need is the last 6 of the VIN and a little info on the type of vehicle (wheel base, GVWR, 4X4 or 4X2) and the VIN can be deciphered from that.
If the OP can provide that information, I will decipher it for them.
'04 F-250 Harley-Davidson 6.0L CC SB
PowerStrokeHD is offline
