Re: Construction Help
About the same price depending on where you get it. Met al is good or the rubber you are speaking of. Do not use asphalt shingle with less then 3 and 12 pitch. It might keep out the water when new, but it will not last with less then that slop. I have built many houses, plus I know a good roofer, and I know that is his opinion on the matter.
1992 F350 Crew Cab 4x4 7.3l IDI E4OD No Turbo
1993 F350 Crew Cab 4x4 7.3l IDI E4OD No Turbo
1990 F250 Super Cab 2x4 7.3l IDI E4OD Utility bed
1987 E250 Quadravan 4x4 6.9 IDI C6 Banks Turbo, Gearvendor, and U.S. Gear Exhaust Brake
