Diesel Forum - TheDieselStop.com - View Single Post - Oil leak ?
Thread: Oil leak ?
Old 12-07-2007, 10:31 PM   #3 (permalink)
JimTJr
JimTJr's Avatar
My Photos: (20)
Re: Oil leak ?
What Kanman says, and have you looked in the valley of the motor? If it is wet with oil from front to back, it is more likely the HPOP fittings or something on the HPOP. Check your valley, and if it is only wet on the rear half, or is dry, pursue as Kan said.
Other possible sources are the EBV actuator seeping, the oil rail plug on the back of one of the heads....
If the whole back is very wet, (oil) clean well, and look again after driving a short distance.
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB. My pics! '03 Dually pics!, New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline   Reply With Quote
