Diesel Forum - TheDieselStop.com - View Single Post - Oil leak ?
Thread: Oil leak ?
Old 12-08-2007, 12:15 AM   #4 (permalink)
loghomeman2
loghomeman2's Avatar
My Photos: (17)
Re: Oil leak ?
I did check inside in the valley of the motor , like you said. I did find oil there it seamed to be in the front part of the motor. I will double check and see if it`s in the back part also. what does this mean if the turbo pedsetal orings are leaking? Turbo going bad? Or just replace the o-rings? I know here is a super dumb ? , but I want to make sure I`m on the same page as you.what is the HPOP? thanks for the great info so far!!I`m thinking your talking about a high pressure oil pump? Does mean that the pump is bad or going bad , or just needs to be repaired?
2002 f250 7.3L psd crew cab 4x4 dark shadow gray with custom pearl silver flames with purple tips pinstriped in burple.rubicon express 6.5" lift with 37x13.50r17 toyo mt tires.AFE stage1 intake, magnflow ss 3.5"-4"exhaust custom 4" ss flame tip,autometer z series pyro,boost,trans temp gauges ,trenzs flame pedals,rv mirror,superchips 1705,ARE Z series cap w/wing,centerline 17x10 cooler wheels,Kenwood HU w/ kenwood graphic EQ mounted in the dash, Kicker 3-way components up front, kicker compontents in rear, w 2 kicker 10" L5 subs powered by kicker KX650.4 & KX850.2 amps Kicke kx3 crossover ,Kenwood 10 disc cd changer,all wired with stinger wire/ blocks/fuses,
loghomeman2 is offline   Reply With Quote
