Re: Oil leak ?
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: flameddarkshadowf250</div><div class="ubbcode-body">I have got an oil leak that has just started , I can`t really find it, but it leaks / drips from the cover that covers the torque converter. I have looked at the oil pan its self and it seams to be okay. Sometimes it leaks alot some times a little and sometimes not at all. Any input would be great!! I hate leaks!! thanks!!</div></div> There is a drain hole up top at the back of the engine. Any oil or whatever gathers in the engine valley will drain out there and down behind the flywheel. It then drips out of that little hole in the bell housing cover. That being said, the most common places for oil leaks are the HPOP hose connections, the rail plugs, the turbo pedestal seal (upper and lower) and the EBPV actuator.
2011 f250 XLT 4X4 Crew Cab.
SOLD - 2001 F250 XLT 7.3L SC/SB 4x4 (ESOF) - Tranny Upgrades; SCMT 1705; AIS Intake w/ trimmed Snorkel; ZooDad; Turbo back 4" Exhaust; Issopro Pillar Mount Gauges; TC lockup LED; Auto Magic Heater Bypass; 2W Low Switch.
