Re: Oil leak ?
So instead of wasting all my time looking for the leak below, I should look inside on top of the motor? I have like 88,000 , So i`ll check the top part and see what I can find! thanks so much to all of you! I hope I can find it soon and that I can fix it! I hate leaks!!!
2002 f250 7.3L psd crew cab 4x4 dark shadow gray with custom pearl silver flames with purple tips pinstriped in burple.rubicon express 6.5" lift with 37x13.50r17 toyo mt tires.AFE stage1 intake, magnflow ss 3.5"-4"exhaust custom 4" ss flame tip,autometer z series pyro,boost,trans temp gauges ,trenzs flame pedals,rv mirror,superchips 1705,ARE Z series cap w/wing,centerline 17x10 cooler wheels,Kenwood HU w/ kenwood graphic EQ mounted in the dash, Kicker 3-way components up front, kicker compontents in rear, w 2 kicker 10" L5 subs powered by kicker KX650.4 & KX850.2 amps Kicke kx3 crossover ,Kenwood 10 disc cd changer,all wired with stinger wire/ blocks/fuses,
