Diesel Forum - TheDieselStop.com - View Single Post - Hallas Performance?
Old 12-16-2007, 04:11 PM   #8 (permalink)
DarkShadowDiesel
Re: Hallas Performance?
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: PwrStrokinDually</div><div class="ubbcode-body">
Almost anyone with some skills can put together a "compound turbo" kit such as the one found on Hallas' truck. "Twins" are matched single turbo's running off of each manifold. It's getting the primary to match up with the secondary that's a little bit trickier as you don't want too small or too large. And you might want to find out just how much hp he was putting out with his twins. I don't know personally, but from other sites I've seen his #s posted he was only in the 500 range on #2 and there are several people doing that with a single charger and over 600 on #2 even. Now don't get me wrong...I'm not talking down about Hallas. Now if someone can prove that he's making more than that on #2 please shed some light on it. I'd like to know that he's making more than that. </div></div>
danny
you need to remember that elmo only made 601whp on that dyno, and considering his trap speeds indicate about 775+ whp, i think it's safe to say that dyno was off. if i recall correctly it was also off for many other competitors.
RCT did those turbos - and they know what they are doing. i do believe this has been discussed and the consensus was that he is making more a good bit more than what the DPC dyno showed.
that said i would not hesitate to send my truck to hallas.
2002 F250
DarkShadowDiesel is offline   Reply With Quote
