Re: Defeating TPMS???
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: PowerStrokeHD</div><div class="ubbcode-body">TPMS is only federally mandated on F-250's, although Ford has chose to make it standard on all SRW F-350's as well. At this time there is no way to disable or adjust the system. </div></div>
I spent nearly 30 minutes reading his owners manual thinking that I'd find which fuse controlled the TPMS circuit. No luck. Plan B is to remove the sensors and hope that there is no chimes, bells, or whistles to go along with the dash light. 80 PSI in the rear tires of an empty F350 is BRUTAL!
Steve Heywood
2005 F250 Crewcab Shortbed 2WD 6.0L
Phoenix, AZ
