Diesel Forum - TheDieselStop.com - View Single Post - Defeating TPMS???
Old 12-20-2007, 04:02 PM   #11 (permalink)
PowerStrokeHD
Re: Defeating TPMS???
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: nickPSD</div><div class="ubbcode-body">I have been running whats listed on the door label. I cant even get the light to shut off after I turn the key off and on 3 times... </div></div>
If you need different pressures front and rear you should have a TPMS reset tool (fob), if so, have you tried the TPMS reset procedure listed in the owners manual? Check the spare tire pressure also. I can not remember if sensors are installed in them or not.
If none of that helps, the dealer is going to need to take a look at it.
'04 F-250 Harley-Davidson 6.0L CC SB
PowerStrokeHD is offline   Reply With Quote
