Diesel Forum - TheDieselStop.com - View Single Post - Defeating TPMS???
Old 12-20-2007, 09:46 PM   #15 (permalink)
PowerStrokeHD
Re: Defeating TPMS???
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: lucky7</div><div class="ubbcode-body">You need to run a minimum of 65 psi in the fronts and 80 psi in the rears to keep the sensors from going off. If you rotate the tires, you need to reset them with the TPMS fob. </div></div>
That is true on the trucks that require 65 front and 80 rear. Some trucks require 65 front and rear and do not include a TPMS fob and do not need to be reset when rotated.
'04 F-250 Harley-Davidson 6.0L CC SB
PowerStrokeHD is offline   Reply With Quote
