Diesel Forum - TheDieselStop.com - View Single Post - Blow off valve and turbo timer
Old 12-31-2007, 02:20 PM   #4 (permalink)
STurbo90
STurbo90's Avatar
My Photos: (9)
Re: Blow off valve and turbo timer
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Bondo</div><div class="ubbcode-body">Hmmmmmmmm,......
What the 'ell is a "Turbo Timer",..??..?? </div></div>
a turbo timer is an electronic timer that you wire to the ign circuit to keep the engine running after you remove the key, to allow the oil to cool down to prevent oil coking in the turbo.
they are usually a timed unit or can monitor egt temp to determine how long to keep the engine running.
that way you do not have to wait in the vehicle for it to cool down before you shut it off.
1995 F350 PSD,CC,LB,E4OD,4WDw4:10LS
IDM Corrosion
Underdash Gauge Pod
Front Tow Hooks
STurbo90 is offline   Reply With Quote
