Diesel Forum - TheDieselStop.com - View Single Post - o-ring sizes, can we get a "sticky"
Old 12-31-2007, 08:22 PM   #1 (permalink)
clydesdale
My Photos: (5)
1. For the fuel drain valve it is #202 viton.
2. For the HPOP hoses and aftermarket crossovers- it is a #5 boss o-ring or -905 (90 durometer .414 ID .072 wd)
Can someone add the pedistal o-rings, IPR o-ring and whatever else they might know? It would likely save time for all of us. It beats searching through the archives. Thanks
2002 F-250, PSD 6-speed, CC, short bed, 4X4, Toreador Red w/ Silver accent, A.R.E mx cap, Weld Super Single II and 33s in the summer, x-springs, F-350 blocks and badges, AIC, proflaps, ITP intank mod, AirDog with 3 micron filter, isspro guages and TTM, scangauge, husky liners, alarm, xm stereo,stull 5399-p grille, centramatics, ccv mod, AIS Air Filter, Southbend CON O, Detroit Truetrac LSD, coolant filter, 203 stat with billet housing, blackcloud intake heater plug/boost fitting, reese titan hitch, fabcraft PTO cover/temp sender port, prodigy brake controller, ITP Boost Annihalator, oilguard bypass filter, Mag-Hytec rear dif, bilsteins, hellwig rear stabilizer bar, ATS housing, non-ebpv pedistal and exhaust flange, magnaflow 3.5dp exhaust, ITP reg return, turbomaster wastegate controller, and ceramic coated bellowed up pipes, PHP 50t and 80p, currently 96,100 miles. truck Pictures
clydesdale is offline   Reply With Quote
