Diesel Forum - TheDieselStop.com - View Single Post - 7.3l idi return o-rings
Old 01-10-2008, 11:26 PM   #6 (permalink)
WilsonJ
Re: 7.3l idi return o-rings
You should be ok, should be. Then again the this issue did just throw me for a big loop. The only leads I have on the condition of the return loop is, if your showing diesel seepage under the injectors collecting in the valleys where the glow plugs sit. I was sure mine were blown when I failed to pull a vacume on one side when I could do it well on the other.
Try here if your interested,
http://shop.dieselpage.com/category.sc?categoryId=29
I have to admit though the McMaster's route might be a good one if you still trust thoes funny little boots are good. Just be sure not to use worm drive hose clamps, only spring clamps and screw type (injector) clamps.
WilsonJ is offline   Reply With Quote
