Diesel Forum - TheDieselStop.com - View Single Post - Who's running Air Bags with a B&W hitch?
Old 01-11-2008, 09:49 PM   #5 (permalink)
ProDriver18
Re: Who's running Air Bags with a B&W hitch?
I'm with rideblue. My bags also mount between the springs and frame. I can't remember if they are model 2400 or what. I do know that they are the correct bags for my application because I called Firestone and talked with a tech about them when I was shopping for a set.
They've been on there for a couple hundred thousand miles now with zero problems. I pull trailers that sometimes weigh up to 16,500 lbs and the bags make a huge difference, I wouldn't do without them.
"Early" '99, 4-98, F350 2WD CC DRW Lariat, Diablo tuner, Swamps 20* HPOP, 4" turbo back straight pipe & a 5" tip, S&B 12" open element air filter, CCV mod, EBV gutted, Vedder's built 4R100 with triple disk convertor, 6.0 trans cooler, Dfuser T/C lockup mod, DieselSite coolant filter, DieselSite TurboMaster, ITP reg fuel return, 4:10 gear w/lmtd slip,Centramatics, Western Diesel gauges, AIC, Ride Rite air bags & onboard compressor kit, Super-Vu convex mirrors, R.D.S. 91 gal. diamond plate aux fuel tank & toolbox combo, B&W gooseneck & 18K companion 5th wheel setup, Rhino lined, Drawtite 1,000lb leveler bars, Drawtite Activator II, Brown's Welding shop (New Braunfels,Tx)full grill/bumper/headlight guard, TurboNet V-Gate.
508,058 miles and still strokin'.
BioDiesel:
Feed a farmer, starve a terrorist.
N.R.A. Life Member
ProDriver18 is offline   Reply With Quote
