Diesel Forum - TheDieselStop.com - View Single Post - Who's running Air Bags with a B&W hitch?
Old 01-16-2008, 07:31 PM   #6 (permalink)
PSDCool
I had a B&W hitch on my 05 F350 w/Firestone air bags don't remember the model number but the bags were installed inside the two frame rails. I normally tow a 5th wheeler weighing in around 17k, let's say king pin weight would be 3.4k. I pump the bags up to 55-65Lbs. and the levels the truck up and removes the rear from squatting. Also, a good trick I use when unhooking the trailer is pumping the bags up to 80 Lbs. so it takes some of the stress off the 5th wheeler landing gear. After I lower the landing gear down then I deflate the bags to about 30Lbs. then I unhook the trailer. I just bought a F450 and I also installed the Firestone bags. Great setup.
2008 F450 Lariat 4X4, Line-X, Pace Edwards bed cover, B&W Gooseneck, B&W Companion hitch, Firststone Air Bags. Everything else stock.
2002 Excursion Limited 4X4, 7.3 with Banks Stinger Plus, AFE, Rear sway bars, Bilstien Shocks
PSDCool is offline   Reply With Quote
