Diesel Forum - TheDieselStop.com - View Single Post - Aux power for interior trailer lights?
Old 01-16-2008, 10:20 PM   #4 (permalink)
MOUNTAINMAN444
You will either have to run another wire that you can hook up constant hot (don't forget to install an in line fuse) or you can put a battery on the trailer to run the lights. This way you can have lights inside wheather it's hooked to the truck or not. If you install a battery you can hook up the switched hot wire in the plug to it to help keep it charged while you are driving.
Joe
2002 F350, Crew Cab, 4WD, ISSOPRO Gauges,
3.73, Auto, 2wd low range mod, No door dinger,
Interior lights off switch, Zoodad Mod,
Extra Trans Cooler, Before coolers trans fltr,
Coolant fltr, Crimestopper remote start/alarm
Oil Guard Bypass, Air horns
MOUNTAINMAN444 is offline   Reply With Quote
