Diesel Forum - TheDieselStop.com - View Single Post - popping under floorboard
Old 01-17-2008, 08:04 PM   #6 (permalink)
94_turbo
orrrrr--as in mine--the rear spring bushings were gone!!!!! i replaced them with urethane ones--end of problem---the eye of the spring was banging the frame-----also--some springs had a rub pad between the leaves--they will go bad--and can make the same sounds---
94_turbo is offline   Reply With Quote
