Diesel Forum - TheDieselStop.com - View Single Post - Is this safe?
Thread: Is this safe?
Old 01-19-2008, 06:03 AM   #7 (permalink)
Leader
Originally Posted by 73LSTROKER View Post
I add a Qt of 2-stroke oil to each tank when I fill up. It doesn't make it smoke anymore than normal but within 5 miles of adding it my idle smooths out and the engine runs quieter.
STROKER
So... The tank that is almost empty already has the oil added from the last fill up & is quiet & smooth. Now you add more oil & in 5 miles it gets quieter & smoother. By now it must be you have to look at the tach to tell if it is running since it is so quiet & smooth.
I'm thinking it's all in your head & the oil doesn't do anything that the average person can notice.
In 379,000 miles I haven't needed or added any additives to my truck & it runs just fine. Still has the original fuel pump & injectors
97 F250 SC LB 4X4 PSD TDE0, E4OD,3.55's, 285/70/16"s ,Modified fuel tank vents, 375+k headed for 500k
Leader is offline   Reply With Quote
