Diesel Forum - TheDieselStop.com - View Single Post - Is this safe?
Thread: Is this safe?
Old 01-19-2008, 07:12 PM   #9 (permalink)
73LSTROKER
Originally Posted by Leader View Post
So... The tank that is almost empty already has the oil added from the last fill up & is quiet & smooth. Now you add more oil & in 5 miles it gets quieter & smoother. By now it must be you have to look at the tach to tell if it is running since it is so quiet & smooth.
I'm thinking it's all in your head & the oil doesn't do anything that the average person can notice.
In 379,000 miles I haven't needed or added any additives to my truck & it runs just fine. Still has the original fuel pump & injectors
NO, if I run strait ULSD for several tanks and then use the oil I DO NOTICE A DIFFERENCE. My truck has a lope when it idles (old injectors) very noticeable the truck rocks and shakes. If I am running 2-stroke the truck runs a lot better. You may want see a doctor for your sensory deficit if you can't tell when your truck it running rite.
96 F-350 Crew cab, Long bed, 4X4, ZF5-
Gauges (EGT, Boost, Trans), TW chip, 3in Downpipe, 17* HPOP, electric fuel system, DIY stage 1s, ZF 5 conversion, ceramic clutch, CCV mod, 285/75/16
On Order: 6.0 VGT turbo, AEM air filter, 4in exhaust
73LSTROKER is offline   Reply With Quote
