Originally Posted by DSTRBD
Yes, we have done a few here at the shop. I will take the Magnaflow kits over any others for the 08'. They have a intercooled tip that is much better looking than the others which use a spiral fluted design on the tail section. I also suggest the S&B intake over the AFE as AFE has had quite a few code issues with their current setup. You can see both on our site. Let me know if you have any questions.
Do you know if the Magnaflow 4" & 5" kits will work with a B&W turn over ball hitch? I ask because I had to lower the stock exhaust with the supplied B&W brackets in order to clear the B&W center section of the hitch.
Thanks,
Gerry
