Diesel Forum - TheDieselStop.com - View Single Post - o-ring sizes, can we get a "sticky"
Old 01-25-2008, 10:08 PM   #8 (permalink)
klhansen
klhansen's Avatar
My Photos: (169)
Originally Posted by firemediceric View Post
Can anyone list the sizes and an after market source for the O-rings on the fuel filter?
Without buying the entire filter, I would like to be able to have an x-tra O-ring for the lid, the beveled one and the one that goes around the filter element.
You could check that link I posted a couple of posts up, but I don't think you'll find the fuel filter lid o-ring, unless you special order and buy them by the 1000's. They are a triangular cross section, not a normal round x-section o-ring.
For the round x-section one at the base of the filter element, you could measure it and match it up to a stock size. For something that big though, it's tough to get a correct diameter without a measuring cone (see the link for info on those). You could get close by using a caliper on the filter element and taking a bit off to account for stretching the o-ring on.
Hard or no-start? Check Here
