Diesel Forum - TheDieselStop.com - View Single Post - Jet Fuel A in 7.3's
Old 01-27-2008, 08:48 AM   #36 (permalink)
fxdwgi
fxdwgi's Avatar
Originally Posted by SkidRowe38 View Post
To answer a couple of questions about JP-5. It is not dyed. It is taken from the aircraft low point drains after it settles for at least 2 hours after fueling before the 1st flight of the day. One of 2 things usually happens with it after that. (1) You either use it to fuel your diesel Ground Support Equipment (which you're not supposed to do, but some of us don't have the patience to wait for the fuel truck to come by and fuel you so you might as well use it as long as it's not contaminated with water and such). (2) You do the right thing and place the fuel samples in either a contaminated fuel drum or a non-contaminated fuel drum based on the outcome of the sample. When the drum is full the hazmat folks come by and take the drum and pay a civilian company to come and take it away. There are a few things to remember here. The fuel is payed for with squadron OPTAR funding which means you are burning fuel payed for by the US gov't. Just a quick sea story and then I'll let you go. Some sailors in Patuxet River Maryland were putting their AVGAS samples into their Privately Owned Vehicles and subsequently ended up going to Captain's mast and were reduced to the next inferior paygrade for doing so. Bottom line is "IT's ILLEGAL". Ask me how I know all this. I'm a 21 year active duty Chief Warrant Officer in the Navy and have held the positions of Material Control Officer and Maintenance Material Control Officer in a F/A-18E Super Hornet squadron.
Oceana ????
2001 F-350 Lariat 4x4 Crew *4" BDS suspension lift w/315-75's * Ford AIS * MKO 5" exhaust * All 4 corners cleared * Front Reese Receiver * Draw Tite Fold Over Gooseneck * Reese 15K Sliding 5er * Gauges Whited Out * IC Foil Delete * Dieselsite Coolant Filter kit * DiPricol Optix White Faced Turbo,Pyro,Trans Gauges w/Dash Mount Pod * DP Tuner F5 60T 80E 120R 140X * John Wood Valve Body * ITP SS X-Over Line * ITP Boost Annihilator * 6.0 Trans Cooler * TCI Truck Master Triple Disc Billet Converter (-200 RPM) * Reviva Transmission * ESOF Converted to Manual Warn Hubs * 203' Thermostat * Turbomaster Wastegate Actuator * Gutted EBPV * Centramatics * Walbro GLS392 * Ford AICM * ITP Pre-pump * One Very Understanding Wife*
I AM AN AMERICAN, SO I DRIVE AMERICAN.
fxdwgi is offline   Reply With Quote
