Diesel Forum - TheDieselStop.com - View Single Post - Member Signature Is Garbled Up
Old 01-27-2008, 09:56 PM   #2 (permalink)
klhansen
klhansen's Avatar
My Photos: (169)
The new system doesn't recognize the formatting codes (or didn't translate them correctly). Just one of the warts that came with the software changeover.
You can fix your signature by clicking on "My Account" in the center of the gray bar under the TDS graphics near the top of the page, then click "Edit Signature" on the left side of the page that comes up.
Delete the formatting codes and format it the way you want, using the toolbar that you see when you're composing a post.
Hard or no-start? Check Here
