Diesel Forum - TheDieselStop.com - View Single Post - Power Steering Pump / Hydra Boost / Brakes
Old 01-31-2008, 05:51 PM   #7 (permalink)
klhansen
klhansen's Avatar
My Photos: (169)
Originally Posted by beaglegun View Post
I'm going to flush the system with Mobile 1 ATF. I've read several posts recomending this. Somebody made up a killer proceedure and put it online.
Power Steering Fluid Flushing Procedure For F250 Superduty Truck
from your link:
"I discovered from reading many posts on TDS that flushing the power steering fluid (ATF) and replacing it with Mobile 1 synthetic ATF might alleviate the problem."
That procedure's been here at TDS for years, but that is a good writeup.
Hard or no-start? Check Here
