I don't think a specific archive search button has been set up yet, but you might try the google search under the search pulldown on the menu bar up near the top. The archives are still there (I have a couple of IE favorites that point there that still work).
OK, I found the old archive search page:
TheDieselStop.Com Archives
On edit (again): Well - That didn't work.
You can however view the archive threads here:
TheDieselStop.Com - www.thedieselstop.com
On edit: Since this might be a common question, I'll sticky it for a while.
99.5 F250 PSD Supercab LB 4x4, ZF-6 w/SB Con OFE, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, DP 80 HP Econo PCM (classic version
), AIS,
coolant filter w/"hokum" bracket, regulated return,
heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check Here
