Where did you gat the new pump? Is it an OEM or "world class" from the generic stores?
If you've flushed it and let the air work out then I suspect the "new" pump may be faulty.
It is common for the steering to be a bit stiff while the brakes are applied because the hydoboost is robbing some of the pressure.
Pump the brakes a few time with the motor off, then push the pedal down and hold it while you start the truck. It should go down some and then stop just like a vacuum type system.
That should give you a clue as to whether the HB is causing some of the problem??
Early '99 F250 SD, 4X4, SuperCab, Long Bed, 7.3L "PowerStroke" Diesel, Auto, PMT1 PCM w/DPTuner 80 tow, 190K miles,
Volant intake, ISSPRO gauges, BDS front leveling kit, 4" straight piped, Dick Cepek 18x9 DC1-Chrome, Nitto Terra Grappler 325/65R18,
Pro GOD, Pro Guns, Pro Life Important Notice, Pro Life changes when someone breaks in.
