Diesel Forum - TheDieselStop.com - View Single Post - Power Steering Pump / Hydra Boost / Brakes
Old 02-04-2008, 08:41 PM   #13 (permalink)
jnyost
I had the same noise after replacing a hose. One of the hoses got a small leak and needed replaced. I was afraid that I had hurt the pump by maybe running it dry. It did end up being air and silenced itself after a while.
Good to know about the Mobil 1 atf. I just used regular atf fluid. Come spring I think I'll drain and refill with a better fluid.
Jared
2002 Excursion Limited 7.3L PSD, Auto, 4x4, 35x12.50-17 Mickey Thompson ATZ, Blue Gold, AFE Stage II with ProGuard7, MBRP 4" stainless, DP tuner (hi idle, stock, 40, 60, 80, 120), Adrenaline HPOP, Coolant Filter, Amsoil bypass filter, Ford rear sway bar, 6 1/2" spring arch.
2000 BMW 540i, 6 speed, sport package, daily driver.
jnyost is offline   Reply With Quote
