Diesel Forum - TheDieselStop.com - View Single Post - Installing CB in '08 Peterbuilt
Old 02-14-2008, 02:30 PM   #5 (permalink)
VCRacing
VCRacing's Avatar
IIRC co-phased antennas need to be around 9' apart for optimum performace, as recommended by Firestik.
I would recommend running a single coax to one side and run a live antenna and a dummy antenna if you want the dual antenna look. As far as tipping the antennas forward, i use Wilson 2000's and they are tipped forward , as i travel down the hwy the wind resistance will cause the antenna whip to flair back to a vertical postion. I know its a PIA to run a single coax but they're easier to tune and maintain.
Ya'll buckle up and pull them belts tight, its gonna get rough..
Mine :01 F-350 CrewCab Lariat 4x4, 7.3 PowerStroke, auto, ShortBox. Mods: 3-Gauage A-pillar W/ Autometer Lunar Guages: boost,pyro,trans; DIY Tymar, Muffler Delete, Galaxy DX-33 Radio W/ Wilson 1000, and Optima RED TOP's, Centramatics, Lund Soft Tonneau
Play:
'82 Ford Bronco 302, auto, Galaxy 33v, Wilson 1000
04 Yamaha G22 E , Jake's Long travel lift kit, Fairway Alloy "Hazard " wheels , 23" EFX Blade tires, Jake's SST Safari Bar and Rear Tube bumper.
Color : PPG Orange Crush Pearl w/ Hi- Gloss Black trim ....
Hers: 00 Pontiac Trans Am, (stock)LS1, auto, T-tops.
VCRacing is offline   Reply With Quote
