I replace brake fluid once a year as general maintenance. For me it is a one person job with speed bleeders. Shipped $37.00 with the clear hose. Brake fluid times out (age) and should be replaced for moisture intrusion. Castrol LMA (lo moisture absorption) fluid is my choice. Moisture will kill a brake system. The color shift in your fluid is the sign of moisture absorption. Glad you changed the fluid, sound like it needed it. Most people do not even think about it until there is a problem and then most times its from age.
Speed Bleeder Bleeding Brakes Bleeding Motorcycle Brakes Automotive Bleeder Screw Brake Bleeder
