Hello Mark,
Well thats where I always start is changing the filters, I have cured a lot of things like you said with just changing the filter. To prime the system on my old Deere Backhoe it has a leaver on the fuel pump that you need to move up and down to get a prime on the pump. I also fill the filter with fuel when I change it. I use the prime leaver for about a minute before I attempt to crank the motor, and BAM starts right up. Hope this helps. Angelo
1997 F-250 CC, Short bed, 134,000 mi, 6" lift, 35" BFG A/T,Open Air element, H2E, Bean Stage II's, 3-5" Tymar DP and exhaust, Dead Cat, BTS Trans., Dana 60 Swap, 4:10 Gears.
