Originally Posted by brocanicbob
I replace brake fluid once a year as general maintenance. For me it is a one person job with speed bleeders. Shipped $37.00 with the clear hose. Brake fluid times out (age) and should be replaced for moisture intrusion. Castrol LMA (lo moisture absorption) fluid is my choice. Moisture will kill a brake system. The color shift in your fluid is the sign of moisture absorption. Glad you changed the fluid, sound like it needed it. Most people do not even think about it until there is a problem and then most times its from age.
Speed Bleeder Bleeding Brakes Bleeding Motorcycle Brakes Automotive Bleeder Screw Brake Bleeder
Which size did you purchase? I went out to their website, but I didn't find anything for 3/4 ton or 1 ton trucks newer than 1997.
short_stuff
Y2K F250 CC PSD Auto, Short-bed Lariat, Woodland Green/Gold, ordered 07/10/99, born 09/12/99, delivered 10/08/99, Access bed cover, Bed Rug, Zoodad mod, Viper Remote Start Alarm, Fumoto valve, 103K somewhat error-free miles (so far) [never back to dealer for anything]
Repairs: CPS, Water Separator Valve assembly, rear axle bearings, VSS, batteries, brakes, alternator, serpentine belt (x2), driver door pwrlock actuator, water pump
2009 VW Tiguan 2.0 l turbo 200 hp gas engine (TDI engine not available for it yet)
