Originally Posted by doczenith1
What are the consequences of damaging the old seals? I ask because I am experiencing a odd problem with my brakes and I cannot figure what the cause is. I had my gf help me bleed the brakes two years ago and there is a very good chance that she pressed the pedal as far as she could. The problem I have is that when I brake really hard and let off the brake pedal the brakes do not release immediately. There is a noticeable pause, maybe one half to one full second. It also seems like it is worse in winter when the temperatures are low. Normal breaking is fine. One year ago I took it to a reputable shop and had them look into it and also change the brake fluid. They were unable to find any problems.
Thanks for the help,
Al
Sticking slide pins.
'02 Black F350srw,Lariat,CC,SB,OR. - BTS TRANS,Coated 1.00 BB TN-non EBP-6.0 Spearco IC-DP Tunes(stock,HI,60T,80E,120R)MAP maximizer- ITP reg ret.-AirDog-Fluidampr- BWD coated/ bellowed pipes -AFE2-4" Magnaflow- Dieselsite coolant filter&ESOF SS lines-Billet/203*stat- Fleetrite ELC-Bilsteins-Hawks&Cryo's-Centramatic-Billet-Extang-Husky box-Husky Liner-EGR-LineX-Alpine-Kicker-PIAA-Dynamat-Sirius-Viper-ES Poly's-BFG 315/75/16 AT's-DTS 4.56LS-31 row 6.0 Cooler-UltraLite trans,pyro,boost-DiPricol fuel-PML pan-Mag-Hytec cover-Powerslot-Hawk. Marinco,Snowman,Harpoon,AIH,CCV,foil,door ding,console mods. http://good-times.webshots.com/album/557543120DKiWId
