Diesel Forum - TheDieselStop.com - View Single Post - Edge Insight Gauge........any thoughts????????????
Old 02-25-2008, 07:44 PM   #32 (permalink)
RRose
The info that should have come from Edge. This is the information that can be monitored with the Insight on the 6.4L Powerstroke (specifically). It took me awhile to put this together..... but I figured someone on here could us it when setting up their Insight!
Ford 6.4L Insight Data Points
Temperature
Engine Coolant Temp
Intake Air Temp
Fuel PIDs
Fuel Rail Press Hi
Fuel Level
Gallons Per Hour
Miles Per Gallon
Air PIDs
Manifold ABS Pressure (MAP)
Mass Air Flow
Barometric Pressure
Boost/Vacuum
Spark/Load PIDs
Calculated Load
Time/Distance/Cnt PIDs
# of Trouble Codes
Engine Run Time
MIL on Distance
Warm Up Counts
DST Since Codes Clear
Time Since DTC Clear
Time Run With MIL
Actuator PIDs
CMD EGR Duty Cycle
EGR Error
ABS Pedal Pos D
ABS Pedal Pos E
Edge EGT – Accessory EGT Sensor
Ford Specific
Ford Fuel PIDs
Injector PW
Ford Air PIDs
Exhaust Temp
Exhaust Temp B1S1
Exhaust Temp B1S2
Exhaust Temp B1S3
Boost (g)
IAT Sensor
Ford Actuator PIDs
Accel Pedal Pos
Trans Input Shaft Spd
Regen Status
Ford Sensor PIDs
Engine Oil Temp
Transmission Temp
Diesel Eng. Oil Temp
Trans Out Shaft Spd
TCC Speed Ratio
Torque Converter Slip
Turbine Speed
Hawk Eye Sensor PIDs
2008, F-250, FX4, Crew Cab, Short Bed, Oxford White w/ black interior, Dual Alternators, Sat. Navigation & Radio, Overhead DVD System, ESOF, Solid Rear Window, 3.73 Limited Slip, Upfitter Switches, Tow Command System w/ Power Scope Mirrors, Power Seats, and the Reverse Aid Sensor - Edge Insight Monitor, 2.5" Donahoe Racing Lift Kit, Fox 2.0" Piggy-Back Shocks, KMC Beadlocks w/ 35" Toyo M/T's, MBRP DPF back exhaust, Recon mirror lights, Fitch Fuel Catalyst, Randy Ellis Design Light Bar, Line-X, MotoBar, Gentex Temp/Direction Mirror
RRose is offline   Reply With Quote
