Diesel Forum - TheDieselStop.com - View Single Post - Fix your fuel leak from filter drain valve
Old 03-03-2008, 11:41 PM   #33 (permalink)
trukpro
i recently replaced the o-rings on the drain valve....picked up the three o-rings off ebay with not so accurate instructions. i had to pull the whole filter assembly from the engine to gain access to the #20 torx screws to remove the valve....after that it was easy. unfortunately it didn't fix what ever is leaking.
justin
'97 f250 ex. cab
trukpro is offline   Reply With Quote
