Diesel Forum - TheDieselStop.com - View Single Post - Fog on windshield??
Old 03-12-2008, 12:42 PM   #3 (permalink)
MikeL46
MikeL46's Avatar
My Photos: (14)
were you running the AC or the defrosters on the way home? Either on turns on the AC. And if the drain tube is blocked, moisture will build up and can fog your window when you stop.
Find AC drain tube ( water drips out of it when you use the AC - or at least it is supposed to) and try and blow air up it.
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
96,258 miles. 16.63 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
176 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, another Alternator, Turbo hose fitting, Block Heater, Door lock, Front axle seals - all under warranty. AC hose, 1 injector, Batteries not under warranty.
MikeL46 is offline   Reply With Quote
