What is this? Smoke after HX crossover install
Hey guys-
Just put on dfuser's HX oil crossover line. After taking it for a quick drive to check for leaks, when I popped the hood there was some very light smoke. No leaks tho.
Anyway, go to the following link, page 3 of 4, and it's the right picture in the middle row that's smoking. That black box w/ 2 bolts and the open hose coming from it. Just some light smoke coming from that hose. Perhaps it's purging air from the install or something? Truck runs n drives great, but I never noticed that smoke before.
Help? Thanks!
http://dfuser.com/Install%20Guides/H...0Crossover.pdf
Jerry
My PSD X
2000 Excursion 7.3L PSD 4X4
DP-Tuner F5 : no start, stock, 40T, Decel, 80T, 80E - AutoMeter A pillar w/ 3 Phantom gauges - DIY Tymar intake w/ S&B conical filter - Zoodad mod - Suncoast Extreme Duty Trans rebuild w/ TransGo Shift kit, Amsoil synthetic ATF & Magnefine inline filer - BD Triple Disc Billet Torque Converter - 4" Stainless Steel Turbo Back (4" down pipe) Magnaflow exhaust - ATS Turbo housing and 4" intake sleeve - Turbo Master Wastegate Controller - HX Oil Crossover - Morse Ceramic brake pads - Monroe Reflex Shocks - Energy Suspension Bushings - IC foil wrap delete - Fumoto Oil Valve - 08' Aluminum Rear Differential Cover - White Night reverse light system - Garmin StreetPilot c340 GPS - 6.o tranny cooler - Dieselsite Coolant Filter w/ CAT ELC coolant - Amsoil Single Bypass Oil Filter w/ Rotella 5W40 synthetic oil - APC white gauge cluster face - Dual in-dash DVD w/ Infinity Reference speakers & Blaupunkt 200A powered sub - 4.5" LED marker/turn lights in front bumper - ViAir HD onboard air system w/ 380C compressor, 2.5 gal tank & Grover stutter tone air horn - FireStone RideRite suspension air bags -
TOWING:
2004 Dutchmen 31BH travel trailer
