Diesel Forum - TheDieselStop.com - View Single Post - What is this? Smoke after HX crossover install
Old 03-18-2008, 09:47 PM   #4 (permalink)
MikeSoderquist
MikeSoderquist's Avatar
Originally Posted by detroitfd View Post
It wasn't there.
And it looks just like the picture in the link, that's now in the first post. It's the tube that's open in that pic. Does it go into the intake tube? Because I have the 4" compressor intake sleeve that comes w the ATS...
Please help quick as I have to drive home in the morning.
Jerry,
The tube you are referring to is the Fords version of the crank case vent. And yes, it is usually routed to the intake... If you have it open like shown in the attached picture(not plugged into the intake) then you will see some smoke/oil vapor coming out of it. The black box that the tube is attached to is actually a filter of sorts that prevents any larger particles from passing into the turbo wheel.
Do you have the black tube vented to air or is it plugged into your intake tube?
Mike Soderquist
"If it ain't smokin', it must be brokin!... or it's just tuned badly..."
- F250 PSD born 4/01 in Kentucky USA, 4x4, 3.73 Rear End, Ext. Cab, Short Bed...
- 4" Pro Comp Lift, 315/75/R16 Pro Comp AT's, Tymar Intake, 4" turbo back exhaust and BTS Valve Body, ITP 3 Gauge Pillar(Pyro/Boost/Trans), Trans & Diff Covers and Rotor Pros Drilled/Slotted Rotors + No-Dust Pads.
~My Truck
MikeSoderquist is offline   Reply With Quote
