That black box is the "doghouse" or CCV cover. If you replaced your stock sleeve that was bolted to the bracket connected to the intake on the compressor, you effectively gave yourself a budget CCV mod. Your venting your crankcase breather into your engine compartment. You need to either reconnect that, or run a 3/4" hose off that rubber 90* and down to the back of your Ex.
I would look into a CCV mod wither off the shelf or homemade. I have one that runs down into a cannister to collect the oily runoff and then out the back of the truck.
2002 X PSD, Billy Boat 4", AirRaid, Gillett Diesel Service Turbo, High Output turbo exhaust housing, KCM HPX Crossover, ITP Overboost Annihilator, Gauges: Boost, EGT, Trans Temp, Fuel Pressure and Water Temp
DP-Tuner 6 pos No Start - 140 Aggressive
Thanks Jody and Diane
Super Heavy Duty / Triple Disc 4R100 built by Jim Galatioto at ATO Transmissions in Sacramento.
