Any moderator...if this is off topic now, feel free to move us or I'll make another thread if you'd rather. Didn't mean to get this to a CCV convo.
However, I never heard anyone say anything about leaks created. I've seen a couple of kits our sponsors make, but it seems the same parts would be MUCH cheaper bought at Home Depot or the like.
NorCal, what's the point of having the 5" rise in tubing if you already have a canister? Just to empty the canister less? And, since I'm new to this mod, I'm assuming the doghouse is that black box with the hose I forgot? The hose on mine swiveled easily...seems like you could just get a double male 3/4" adapter btwn that hose and a new length, run the hose down into the top of the canister w/ your petcock, and then another hose out of the top routed to the back to get rid of vapors? Does the "vapor line" need to be 3/4"? And do you use heater hose for the 3/4", or does it matter what you use as long as oil resistant?
Jerry
My PSD X
2000 Excursion 7.3L PSD 4X4
DP-Tuner F5 : no start, stock, 40T, Decel, 80T, 80E - AutoMeter A pillar w/ 3 Phantom gauges - DIY Tymar intake w/ S&B conical filter - Zoodad mod - Suncoast Extreme Duty Trans rebuild w/ TransGo Shift kit, Amsoil synthetic ATF & Magnefine inline filer - BD Triple Disc Billet Torque Converter - 4" Stainless Steel Turbo Back (4" down pipe) Magnaflow exhaust - ATS Turbo housing and 4" intake sleeve - Turbo Master Wastegate Controller - HX Oil Crossover - Morse Ceramic brake pads - Monroe Reflex Shocks - Energy Suspension Bushings - IC foil wrap delete - Fumoto Oil Valve - 08' Aluminum Rear Differential Cover - White Night reverse light system - Garmin StreetPilot c340 GPS - 6.o tranny cooler - Dieselsite Coolant Filter w/ CAT ELC coolant - Amsoil Single Bypass Oil Filter w/ Rotella 5W40 synthetic oil - APC white gauge cluster face - Dual in-dash DVD w/ Infinity Reference speakers & Blaupunkt 200A powered sub - 4.5" LED marker/turn lights in front bumper - ViAir HD onboard air system w/ 380C compressor, 2.5 gal tank & Grover stutter tone air horn - FireStone RideRite suspension air bags -
TOWING:
2004 Dutchmen 31BH travel trailer
