Originally Posted by detroitfd
However, I never heard anyone say anything about leaks created. I've seen a couple of kits our sponsors make, but it seems the same parts would be MUCH cheaper bought at Home Depot or the like.
The leaks arise when a positive pressure is trapped inside the crank case... That positive pressure, although very slight is enough to push oil out of seals. The idea of CCV is to bleed off that pressure inside the crank case. There is a very slight chance that the original vent would ever get clogged, but when you route the vent to the back of your truck with 5 or so ft of hose, there is a greater chance that the hose could become bent or get clogged and not allow the crank case pressure to vent.
Mike Soderquist
"If it ain't smokin', it must be brokin!... or it's just tuned badly..."
- F250 PSD born 4/01 in Kentucky USA, 4x4, 3.73 Rear End, Ext. Cab, Short Bed...
- 4" Pro Comp Lift, 315/75/R16 Pro Comp AT's, Tymar Intake, 4" turbo back exhaust and BTS Valve Body, ITP 3 Gauge Pillar(Pyro/Boost/Trans), Trans & Diff Covers and Rotor Pros Drilled/Slotted Rotors + No-Dust Pads.
~My Truck
