Diesel Forum - TheDieselStop.com - View Single Post - superduty car computer touchscreen?
Old 03-19-2008, 12:36 AM   #1 (permalink)
westvandude
westvandude's Avatar
Anybody running a "carputer" in their superduty? What screen did you use in the double-din stereo opening and how do you like it?
I got an older thinkpad T22 laptop from a friend which I'm repairing (needs new mobo - loses cpu fan control - got one on ebay cheap). Then going to get a docking station. I already got a 12v to 16v power supply to run it.
If you've never heard of this stuff check out:
MP3Car.com - Your source for mobile computing solutions! - Home
https://www.timekiller.org/carpc/index.php
Do a search on google for "car pc".
Anyway, I figured a $200 laptop with decent power and getting a docking station (ebay cheap) would be a better solution than a dedicated car pc for $500+. If you install a $15 docking station in every vehicle you own you take your tunes with you.
Just need to find a decent computer fm tuner.
They make external usb or firewire dvd reader/writers too. Only your wallet and your imagination are limits.
More links:
Clear Cut Audio Systems, Car Audio Computer Systems
2002 Ford F-250 - Page 3 - MP3Car.com (sweeeeeeeeeeet!)
2002 Ford F-250 - MP3Car.com (same one)
2001 F250 4x4 crew lariat 7.3L auto, DP Tuner F5 no-start/valet/20tow/80econo/140aggressive, Adrian Tavano's triple disc converter, transgo tugger HD2, ISSPRO egt/boost/pyro, foil delete, 6" stainless tip, Magnaflow 17979 4" turbo-back, dieselsite boots & coolant filter kit, HX crossover, boost fooler & tru-cool trans cooler, ported turbo housing, DIY 6637 Tymar, billet grill, line-x bedliner, bug deflector, tint, 08' alum diff cover, clear corners & tails, silverstar bulbs, Xtreme XT855 reverse lights, 1500w inverter, Tekonsha Primus, EQX, Epicenter, Autotek MM4000.1D, 2x Audiobahn AWT12X, 2/0 cables, JVC KD-AVX44 El Kameleon dvd deck, 12.5" flipdown video.
2009 VW Jetta 2.0TDI 6spd Highline full load except nav. 19" Audi RS6 rims. Custom fiberglass hifonics 12" sub & 280w usacoustics amp. Tint is next.
westvandude is offline   Reply With Quote
