Originally Posted by MikeSoderquist
The leaks arise when a positive pressure is trapped inside the crank case... That positive pressure, although very slight is enough to push oil out of seals. The idea of CCV is to bleed off that pressure inside the crank case. There is a very slight chance that the original vent would ever get clogged, but when you route the vent to the back of your truck with 5 or so ft of hose, there is a greater chance that the hose could become bent or get clogged and not allow the crank case pressure to vent.
All true, that is why I used Heater Hose because it is more rigid than regular rubber hose. I also made sure that no kinks were in the line running down to the new cannister and made sure to lock the hose down with a couple brackets along the way. I also made sure to route the exit hose from the cannister all the way out the back of the vehicle. I thought about welding a 3/4 bung to the end of my exhaust. That would probably pull the CCV vapor through the line and into the soot mix, but decided against the extra work. I would not tap into the exhaust before the muffler since there would be back pressure that would cause the CCV to add pressure to the already pressurized Crankcase. All in all it is a good mod. I have no oily residue in the charged air side and I removed my Intercooler and cleaned the existing oil residue from there. I don't know how much that bought me, but I know it is clean.
2002 X PSD, Billy Boat 4", AirRaid, Gillett Diesel Service Turbo, High Output turbo exhaust housing, KCM HPX Crossover, ITP Overboost Annihilator, Gauges: Boost, EGT, Trans Temp, Fuel Pressure and Water Temp
DP-Tuner 6 pos No Start - 140 Aggressive
Thanks Jody and Diane
Super Heavy Duty / Triple Disc 4R100 built by Jim Galatioto at ATO Transmissions in Sacramento.
