I used one of those FM tuners once. I hated it, seemed like the power was so low I couldn't pick up a good signal with it on the dash in the middle. I just bought a DF-FORD20 Aux Interface from Crutchfield and love it. Plug and play. Seriously. It was $70 or so and took me all of 5min to install. Just don't run your audio wires next to the power wires or you'll get bad noise. Or just run a shielded wire and you should be find as long as your system is properly grounded.
'02 F-350 "Babe The Big Blue Truck" 4x4, Ext. Cab, 8' bed
DP-Tuner 80T, ATS Compressor housing, DIY intake, openair CCV, 80HP 'pane shot, SBC DD all ceramic clutch, ISSPRO boost/pyro gauges, 4" lift, 255/70R22.5 tires, brake linelock, 16 flashy lights, 12 strobes, 12 switches on console, 9 switches on the dash, 7 two-way radios, 5 air horns, laptop, siren, 105 gal. in-bed fuel tank, and who knows what else... oh and a Kennesaw Mountain front bumper (now tried and true)
'66 Bronco "Big Little Monster" - 5.0L EFI, AOD, D20, 3.5" WH sus. lift, 3" body lift, 35" BFG muds, Stock Dana 30 front with Lock-Rite, disk brakes, Warn Hubs, Stock Ford 9" rear with mini spool
