Not a carputer but I just installed an Eclipse DVD/NAV in my '01. What I learned was ya don't get a 'true' double-din opening until '05. The earlier trucks are just a little shy of 4" tall opening. Sounds like you're not using too many 'off the shelf' components so it shouldn't matter, but I was suprised. I was able to fab my own mounting system/brackets and it turned out good, but it was not plug-n-play!!
Choose wisely. Or PLEASE post pics of the carnage!!!
2001 F-350, DRW, 4x4, XLT Crew Cab, flat bed, 7.3, 6 spd, Dipricol Optix gauges on pillar - EGT, Boost, Fuel Press., HPO Press. - No Muffler, AIH delete, SB Con OFE, AC code injctrs, GTP 38R. Vegistroke-inspired WVO system w/150,000 trouble-free miles! BTS tunes, 203 t-stat w/billet housing, Evans coolant, coolant filter, boost relief valve, Dieselsite IC boots, Hella headlight harness, '07 grill/lites and big, bad front bumper!
2000 Excursion 4x4 Limited - BTS trans and tunes, AIS, Frybrid/V3 SVO conversion with over 100k VO miles so far!
That's 250k miles on SVO between them!
