ScanGaugeII - is it any good?
I was wondering if anyone has used the ScanGaugeII. Is it any good as a Trip Computer? What about as a code reader? I assume that since it is getting its data from the Truck Computer that its accuracy may be similar to the factory ones - which I have not heard a lot of good about (my truck doesn't have one).
Thanks,
Mike.
2001 F350 Crewcab 7.3L PSD, 6-Speed, 3.73, 265/75R16
Airaid Cold Air Intake, Stock 3 1/2" exhaust straight piped, Plastic bed liner delete, Tuff Liner spray in bed liner, Leer hi-rise canopy, CCV Mod, Coolant Filter, Coolant Flush - Zerex ELC type, 203 Tstat, Upper Rad. Hose Mod, AIH Delete, Foil Delete, Intercooler Flush, HP Crossover, Fumoto Drain Valve, AMSOIL - 9K so far, next OA at 13K, ISSPRO EV Gauges, EBPV Brake (manual switch), Wastegate controller
Wishlist:
DP Tuner, Bellowed Up-pipes, IC and Engine Boots, 4-5" exhaust, Short Shifter, Regulated return
<>< Grateful believer in Jesus Christ
