Originally Posted by mt454casull
Hey,
I I have been told not to run dello 400, and that it isn't approved for International engines anyhow. Any how, what are your thoughts?
Never heard that one. I've been running Delo 400 with 7500 mile changes. I would go to 5000 mile changes except I never drive less than 30 minutes after I start it, never idle longer than a stop light, and IH has 10000 mile changes on the same engine.
Delo 400 has the same approvals as other diesel oils and it works for me.
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
96,258 miles. 16.63 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
176 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, another Alternator, Turbo hose fitting, Block Heater, Door lock, Front axle seals - all under warranty. AC hose, 1 injector, Batteries not under warranty.
