Diesel Forum - TheDieselStop.com - View Single Post - Installed ATS housing, Have one question????
Old 03-23-2008, 08:05 PM   #1 (permalink)
remedm
remedm's Avatar
How the he!! do you get the c clip back on the waste gate,
I bought 3 extra and lost them all.
I have a machine shop and think I am going to
make a round coller with a set screw in the side.
Unless you guyes know another trick ??????
The job was pretty easy, I spent the most time
trying to get the c ring back on. Never did!!!!!!!!!!!!!!!!
It is just sitting on there now, Not sure what would happen
if it came off, Drove home it was fine.
Also installed the ford AIS system.
I like the cleaner look and the Woooooosh
sound is gone, You can actually hear the truck now.
Thanks for all your help, There is great info on this site!!!!!!
Back to the question, Is there a trick or do you have to buy
alot of c rings and you just get lucky!!!!!!
2002 CC F-350 SB SRW 4X4 TOREADOR RED
DP-TUNER NO-START, MOD STOCK, HIGH IDLE, DRIVE THRU, 40 TOW, DECEL, 60 TOW, 60 ECON, 80 ECON, AND RACE
BTS TRANNY (NUFF SAID) ; 6.0 COOLER
DIESELSITE BOOST RELIEF VALVE, 203^ THERMOSTAT AND HOUSING, MAX A/C VALVE AND COOLANT FILTER
ATS TURBO HOUSING, FORD A.I.S., OILGUARD BY-PASS, 4" MAGNAFLOW STRAIGHT PIPE, SIDE EXIT,
NCHORNET'S CCV MOD, POR-15 OIL PAN
ISSPRO A-PILLAR PYRO/BOOST/TRANS, ISSPRO ENGINE, OIL TEMP AND VOLTS OVER MIRROR
MARINCO MOD, LED ID BAR, HEATED SIGNAL MIRRORS, LED BRAKE AND TURN SIGNAL BULBS FRONT AND REAR
RHINO BED LINER, SIRIUS RADIO ,
AMERICAN EAGLE WHEELS WITH 305-70-16 NITTO TERRA GRAPPLERS WITH A 2" DONAHOE LEVELING KIT
TRUCK BUILD DATE 1/8/02
BTS BUILD DATE 1/8/07 AT 41K
My Truck
remedm is offline   Reply With Quote
