Originally Posted by airfooter
I borrowed one from a friend. If you've been to their site you see what it can do. If you program the right codes in it, and your computer puts out, it will give you some cool info.
I could not get it to tell me cyl. head temp, barometric press., water temp, and several other things I wanted to know. It religiuosly told me I was getting 9.8 mpg - at 50mph w/cruise on for miles or 80 and belching smoke.
I did like reading and clearing codes at a red lite. The digital tach, volt meter, etc were cool. I'll get it again when I get back in a couple weeks, and contact scangauge for help gettin' those features to work - if they will...
It was like $169 - right?
Yes, they retail for $169 and you can buy them for about $159 at online retailers.
So is the one you borrowed a "II" or the original? From their website, they made a lot of improvements over the original.
Mike.
2001 F350 Crewcab 7.3L PSD, 6-Speed, 3.73, 265/75R16
Airaid Cold Air Intake, Stock 3 1/2" exhaust straight piped, Plastic bed liner delete, Tuff Liner spray in bed liner, Leer hi-rise canopy, CCV Mod, Coolant Filter, Coolant Flush - Zerex ELC type, 203 Tstat, Upper Rad. Hose Mod, AIH Delete, Foil Delete, Intercooler Flush, HP Crossover, Fumoto Drain Valve, AMSOIL - 9K so far, next OA at 13K, ISSPRO EV Gauges, EBPV Brake (manual switch), Wastegate controller
Wishlist:
DP Tuner, Bellowed Up-pipes, IC and Engine Boots, 4-5" exhaust, Short Shifter, Regulated return
<>< Grateful believer in Jesus Christ
