Diesel Forum - TheDieselStop.com - View Single Post - Help Massive Oil Leak at Turbo Pedestal
Old 03-24-2008, 10:56 PM   #2 (permalink)
klhansen
klhansen's Avatar
My Photos: (169)
There's a couple of things you can do to fix it. Either way you'll have to remove the pedestal (and replace the o-rings you thought were leaking.)
You can rebuild the EPBV actuator with a seal kit (around $100)
or you can tear the pedestal apart and plug the ports that allow oil into and out of the piston housing for the EBPV actuator. Don't have any specific instructions on how to do that, but I recall someone posting about it with photos. Try a search for EBP Delete.
Hard or no-start? Check Here
