Diesel Forum - TheDieselStop.com - View Single Post - Direct Switch for wiper Motor
Old 03-29-2008, 11:45 AM   #4 (permalink)
cdnsarguy
cdnsarguy's Avatar
My Photos: (109)
Small cooler would be the trans cooler most likely......... so would the lines be from the trans to the rad cooler portion of the trans cooling system.
Couple posts re what I think is your other problem........
1/
You have the typical intermitant wiper module failure. The good news is it is an easy fix.
Follow the wires off the back of the switch down to the module. The module is located on top of the emergency brake pedal bracket. Once you remove the module open it up carefully. Inside is a circuit board with some electronic components and a couple of relays soldered to it. If you remove this board and flip it over you will find a broken solder joint on one of the relays. Take a soldering iron and resolder it. All Fixed
Posted by Ken
2/
After viewing several posts on wiper problems I decided to tackle the "black box" wiper delay control under the dash. After I got the thing out , unplugged, and in my hand I pulled it apart as described in other posts and I found just what I was told I would find, broken solder joints (3) connecting what appears to be a switch/relay mounted on a sheet metal "platform" with 2 "wings" (heat sinks?). The 3 jounts connect the switch and the 2 legs of the "platform" to the circuit board. I re-soldered the connections, flipped the board over and then used JB weld to glue the legs of the "platform" down to the board and used a big dab to glue the side of the platform to the side/end of the black "cube" which sits next to the platform on the board. This glue job will help the platform stay in place under vibration better than the weak solder joints in the stock set up(I hope). Hard to describe but if you open the box (2 screws) you will see what I am describing pretty clearly. I re-assembled the board in to the box, reversed the metal mounting bracket (used same holes in box and bracket but rotated it 180 deg.) Then re-mounted the unit under the dash in a place well away from vibration (I hope). I used a rubber washer (made from an inner tube) between the truck and the mounting bracket this should keep vibration down (I hope). I now have two (2) constant speeds: slow and " a little faster", and I also have my intermittent settings back. YEEEE HAWWWW!! Saved some green, justified my hanging around this site to the wife, all is well and good.
Thanks to previous posters who suggested opening the box.
Good luck
Proud Canadian BOOB man too!!
cdnsarguy is offline   Reply With Quote
